Home › Forums › Products › Rackmount › H9000 : How to side-chain a compressor to create a ducker? › Reply To: H9000 : How to side-chain a compressor to create a ducker?
#152039
zazula
    macgee wrote:
    You can try this if you want – I needed to add a comp to an algo I’m working on so just built Comp on it’s own with sidechain
    The detector config is what you use to choose from different Input sources, stereo, mono or summed
    Pop on USB Key and can import on H9000
    https://www.dropbox.com/s/68cjt2x0cfs6clc/Comp%2BSideChain%201_4132979866.9ka-CompiledALGO.zip?dl=0
    Let me know if any issues
    Are you using Vsig for this?  Does Vsig work for the H9000?  I was using VsigX on MacOS but may need to format a computer with windows if Vsig is working for the H9k.
