Home Forums Products Rackmount H9000 : How to side-chain a compressor to create a ducker? Reply To: H9000 : How to side-chain a compressor to create a ducker?
#152045
zazula
    macgee wrote:
    You can try this if you want – I needed to add a comp to an algo I’m working on so just built Comp on it’s own with sidechain
    The detector config is what you use to choose from different Input sources, stereo, mono or summed
    Pop on USB Key and can import on H9000
    https://www.dropbox.com/s/68cjt2x0cfs6clc/Comp%2BSideChain%201_4132979866.9ka-CompiledALGO.zip?dl=0
    Let me know if any issues
    I just tried loading this and it doesn’t show up on the H9000.  Formatted USB stick FAT and put the k9a file on it.  I don’t see any entries when I say “Load Algorithms”.  It does say that it “read EFI” when I put the USB stick in.  I’m on firmware 1.1.5.
