Home › Forums › Products › Stompboxes › Pan and stereo delay › Reply To: Pan and stereo delay
#152055
mjahoger
    Iceman78 wrote:
    Hi to every one, i’ ve bought a h9 few days ago but as a newbie i’ve some difficulties with the device. I would to know if i can pan a reverb only on one output. Also if i can use a stereo delay with two different settings of time, feedback and mix. Is it possibile?
    You can pan the reverb in one channel, by setting the routing of the H9 to “wet-dry” (under Pedal Settings>General Settings>Routing).
    You then can choose for each individual preset whether you want the effect in stereo, wet(L) dry(R), or dry(L) wet(R).
    With respect to the stereo delay, several delays have individual settings for time and feedback, but mix is always the same. However, feedback settings do affect mix levels.
