Home Forums Products Rackmount Eclipse midi program numbers. Reply To: Eclipse midi program numbers.
#152088
It sounds like you have a number of options:
1) If the Eclipse starts at zero and your controllers can be set to start at zero, this could be a solution.
2) If the above is not true, you can use the MIDI map to connect any Program Change to any Program.
This is less difficult than you think it is.
