Home › Forums › Products › Stompboxes › New 2019 algorithm release? › Reply To: New 2019 algorithm release?
#152094
    mjahoger wrote:
    mustafaicil wrote:
    I would love to have a delay algorithm where Delay A goes into Delay B as with two separate delay pedals connected in serial.
    You can already have a mono series delay by putting a patch cable from output A into input B. Alternatively, the delays in the Filterpong and SpaceTime algorithms have series delays.
    Using a patch cable, you cannot use different delay settings for each. So not a very preferred solution. Plus that affects every algorithm used. I have not tried Filterpong and Space in that manner. I will check them again.
