Home Forums Products Stompboxes H9 – Controlling Volume with express pedal in a defined range (e.g. from 0bd to +2db) Reply To: H9 – Controlling Volume with express pedal in a defined range (e.g. from 0bd to +2db)
#152134
mustafaicil
    lele77 wrote:
    Hi everybody
    I would like to control the volume parameter of each preset with the expression pedal in the same way I’m controlling the other parameters (e.g. adjusting at the same time the amount of the mix and increasing the volume from 0 to +2db). Is it possible?
    It seems volume is the only parameters that cannot be adjusted with the expression pedal from one value to another (e.g from 0db to +3db)
    As far as I know Eventide planned to “solve” this issue some years ago so I’m wondering if there is some progress about this topics.
    Thankyou
    Emanuele from Italy
    +1
