Home Forums Products Stompboxes Timefactor will not go in to Update Mode Reply To: Timefactor will not go in to Update Mode
#152153
nutrapuppy
    Thanks for the reply Nick. I agree with your advice for sure. I have redundancy in the form of other delay pedals, rack stuff like an Axe FX 2 XL+, and plugins of all sorts, so I am not concerned about being unable to perform so much as I am keen to fnd creative inspiration by way of the ol’ Timefactor. It has a thing that goes beyond the specs and algorithm names. I can’t put it into words. If you know what I mean and can put it into words, please advise.  wink
    Support did reply and asked about the switch, so i did some more tests and determined the switch is intermittent at best, and by the time I had goofed around in loop mode for 5 minutes, it had basically totally failed. Interesting to note, that one switch was very rarely used at all. The original TAP switch did not last very long either (tho I tap way more than might be expected). Perhaps some of those early ones had a run of faulty switches and I just got unlucky there. I ordered a couple spares and should be in business next week.
