Home Forums Products Stompboxes Trying to create a repeat or delay setting that will repeat back a preset set length when the aux switch is engaged Reply To: Trying to create a repeat or delay setting that will repeat back a preset set length when the aux switch is engaged
#152190
    Off the top of my head, I’m thinking the UltraTap algorithm (MultiTap is a fixed 5 repeats).
    https://www.eventideaudio.com/products/algorithms/ultratap
    Ignore & zero out all of the controls except MIX, LENGTH, & TAPS.  Set TEMPO = ON.
    Adjust TAPS to the maximum amount of repeats you’ll ever want.  Divide that number of repeats into the overall delay LENGTH, for 1/4 Note on each repeat.  Tie the aux switch to MIX, and momentarily shift from a 0 value to 50 (or whatever MIX delay level is appropriate).
