Home Forums Products Stompboxes Trying to create a repeat or delay setting that will repeat back a preset set length when the aux switch is engaged Reply To: Trying to create a repeat or delay setting that will repeat back a preset set length when the aux switch is engaged
#152191
bohan
    davebrubaker wrote:
    I'm assuming this is possible. Any suggestions? Thanks in advance for your thoughts.
    Are you talking about H9 or TimeFactor? On TimeFactor, you can use the middle footswitch to repeat the delay. On H9, you can map your aux switch to "Performance Switch (aka Middle Footswitch)". You can do the mapping on the unit or in H9 Control (Pedal Settings -> Aux Switch Mappings)
