Reply To: Modfactor and Powermax – incompatible?
Home Forums Products Stompboxes Modfactor and Powermax – incompatible? Reply To: Modfactor and Powermax – incompatible?
#152201
h9controller
Hi tmart,
The green power supply cables included with your PowerMax should fit your ModFactor's power jack.
Is there a possibility the unit was ever repaired, maybe by a previous owner and an incorrect power jack was installed?  If the power tip is too skinny, you'll run into the intermittent issue you described.
