Home Forums Products Plug-Ins Ultrareverb not showing in Studio One Reply To: Ultrareverb not showing in Studio One
#152276
tlongabaugh
    Curtsong wrote:
    Having the same issue. Just purchased the Ultra plugin promotion you had. all the new Ultra Plugs aren't showing up in s1 4Pro. I'm a windows platform.
    I had the same issue with the H3000 too.  The .dll files have to be placed into the VST3 folder because that's how S1 uses VST3 plugs.
    on Windows if it's an x64 VST3 it has to be in Program FilesCommon FilesVST3 to scan and load.
    Hi-
    We currently don't support VST3. The .dll files are VST2.
    In order to use the plugins, you should install them into the location you are using for your VST2 plugins. They are installed to the following locations by default. Please make sure that Studio One is set to look at the applicable custom folder:
    1. VST32: c:Program Files (x86)Common FilesSteinbergVST2Eventide
    2. VST64: c:Program FilesCommon FilesSteinbergVST2Eventide
    You should also ensure that you've activated the licenses in iLok License Manager.
