Home Forums Products Rackmount best lowpass/hipass filter for quick, low latency sweeps? Reply To: best lowpass/hipass filter for quick, low latency sweeps?
#152282
macgee
    Thanks pmcculloch…
    This was at the default Q of 0.5 so shouldn’t have been that? I should try reduce the gain and see if that makes a difference In case.
    I’ll try the modiirq filter as well.
    I’m not familiar with Butterworth filter design. Are you able to share a short description of how to achieve that in Vsig land? Everything I found was about the maths or electrical..
    Sadly it’s nearly impossible to find Vsig style designs…
    pmcculloch wrote:
    modiirq is probably going to work better for high frequency sweeps, though you can't control the Q at audio rate.
    One thing that's important to remember is that when you stack up filters you're also stacking up any gain that those filters introduce.  (e.g. if you have a Q of 1, you're going to introduce some gain.  More sections = more gain)  If you want a higher order filter that doesn't introduce gain, you might look at something like a Butterworth filter (you would need to cascade multiple filters for that)
