Reply To: H9K – DMYSMP2/N
Home Forums Products Vsig and Preset Development H9K – DMYSMP2/N Reply To: H9K – DMYSMP2/N
#152335
macgee
I’ve uncovered the following strange behaviour, please confirm if this intentional
When using DLYSMP2, with Playspeed set to -100%
If you have LOOP MODE = 1 and you’re DUBBING, then it will just play forward.
If however you have LOOP MODE = 0 & TIMEOUT MODE = JUMP TO PLAYING, then it will play backwards.
But there’s no way to have the SAMPLER work automatically and play in Reverse or at slower or faster speeds
By recording and then playing back, then reverse works but not slower or faster playing.
It is necessary to be able to record at 100% but playback at different speeds including in REVERSE  with LOOP MODE = 1 & DUBBING which isn’t currently possible and requires a lot Hacking to simulate with limited success
