Home Forums Products Stompboxes Timefactor goes nuts! Reply To: Timefactor goes nuts!
#152535
DaiF
Thanks. Still can’t figure out why the Timefactor works fine for some time before the issue recurrs out of the blue. If my connections were the cause wouldn’t the problem always be there? Also I’ve used other dalays in the same way (amp send to input A, output A to amp return) with no problem. I appreciate your reply though.
