Home Forums Products Stompboxes Time Factor: OUTPUT 1 less volume than OUTPUT 2 when in stereo Reply To: Time Factor: OUTPUT 1 less volume than OUTPUT 2 when in stereo
#152570
bohan
    maxigtr wrote:
    It happen with the TF in ON and OFF. And no matter dly mix were. All in A or all in B its the same. Output A have less volume
    If you connect your TF to your PC/Mac, and open the level meters in the “Pedal Settings” screen of the H9 Control, can you see the difference between 2 Output channels?
