Home › Forums › Products › Stompboxes › H9 Output Level control with expression pedal? › Reply To: H9 Output Level control with expression pedal?
August 28, 2019 at 1:14 am
#152633
Eventide added expression pedal control of either the input or output volume on a preset by preset basis some time ago. If you select any algo and then select the “More” option in the top right hand corner, you will see a window where these two options are at the top.
