Home Forums Products Stompboxes Dual Mono setting – Timefactor Reply To: Dual Mono setting – Timefactor
#152635
    It's not a setting as such. If you only plug in a single output (must be OUT 1), the unit will feed a mix of the two effect outputs to it.
    It does not do dual mono (in most cases), it's either stereo or mono.
