Home Forums Products Stompboxes H9 Output Level control with expression pedal? Reply To: H9 Output Level control with expression pedal?
#152638
FatBulli
    Thank you for your rapid replies. So much for me paying attention to new features:-) apalazzolom this is what I was looking for.
    Can I ask if controlling inout or ou.tput volume per preset also can be set with min an dmax, like the other parameters you assign to an expression pedal in a preset?
    The purpose is to add volume and increase certain pramaters primarely for leads since I run effects like reverbs and delays post routing in the loop.
