Home Forums Products Stompboxes H9 Output Level control with expression pedal? Reply To: H9 Output Level control with expression pedal?
#152647
FatBulli
    Again, thank you for replying so quickly. This gets me towards the desired effect. I hope you can take into consideration, the possibillity to assignthe “out level” per preset similar to other parameters in future releases of the firmware.
    I believe it would be very cool to be able to increase out level, together with for example feedback and modlevels, especially for lead using delays:-)
    Keep up the good work, your products absolutely rock!
