Home Forums Products Plug-Ins H910 Harmonizer not showing in Reason 10 Reply To: H910 Harmonizer not showing in Reason 10
#152676
tlongabaugh
    Hm, okay. Can you try these steps and let me know the result?
    1. Confirm that you have the latest version of the plug-in installed: https://www.eventideaudio.com/products/plugins
    2. Confirm that you have the latest version of iLok License Manager installed (www.ilok.com).
    3. Make sure the plug-in license is activated to your machine or iLok dongle in the iLok License Manager.
    4. Close your DAW and run the plug-in Uninstaller. The uninstaller is located at Start Menu->Control Panel->Programs and Features->Uninstall a Program
    5. Open your DAW and rescan you plug-ins, and then shut your DAW again.
    6. Deactivate and reactivate the plug-in license in iLok License Manager.
    7. Reinstall your plug-in. If you are installing VST2 to a custom folder, make absolutely sure you are installing the correct 32 or 64-bit version to that folder.
    8. Reopen your DAW and rescan your plug-ins.
