Home Forums Products Stompboxes Powermax compatibility with BOSS MS-3 Switchter Reply To: Powermax compatibility with BOSS MS-3 Switchter
#152799
joseines
    I got my answer from a website
    Amperage
    USB ChargerMany people are confused by amperage ratings and what they mean when it comes to power supplies and replacements.
    The amperage rating is the maximum amount of power it can supply.
    One way to look at it is as if amperage were “taken” (often referred to as “drawn”, as in pulling) by the device being powered. That device will only draw as much amperage as it needs to perform whatever it’s doing. Your computer will use more power, in the form of higher amperage draw, when it’s working hard than when it’s not. (Voltage remains the same regardless.)
    Thus, as long as you replace your power supply with one capable of providing as much or more amps than the previous supply, you’ll be fine.
    If for some reason your replacement power supply has a lower-than-required maximum amperage rating, you may end up with a burnt out or overheating power supply, and the device itself may not function.
