Home › Forums › Products › Stompboxes › H9 stopped receiving MIDI signals through DIN5. › Reply To: H9 stopped receiving MIDI signals through DIN5.
September 30, 2019 at 8:07 pm
#152809
nickrose wrote:
Make sure that the USB cable is not connected to the H9 – it can only use ONE of USB or DIN, and if the USB is connected it will not read DIN.
Thanks, nickrose, for that advice, but no USB is connected.
Regular power cycling has not solved the issue. Would a factory reset be worth a try?
