Reply To: Eventide Rose – MIDI Clock
Home Forums Products Stompboxes Eventide Rose – MIDI Clock Reply To: Eventide Rose – MIDI Clock
#152855
pepeflores2003
jallard wrote:
The public beta version (3.02) and later support MIDI clock. See the Beta 3.0 User Guide Addendum here for instructions on enabling MIDI clock:
https://www.eventideaudio.com/support/product/12425/manuals
MIDI Clock:
– Hold ACTIVE + PHI until all LEDs are on
– Press PHI to enable MIDI clock (bottom most Shape ladder LED lit) or disable MIDI clock (all SHAPE ladder LEDs off)
– Press ACTIVE or HOTSWITCH to exit
Once enabled, MIDI clock will be received and transmitted on both MIDI-TRS and MIDI-USB. MIDI clock works like tap-tempo with 24 clocks per quarter-note. Tap divisions work with MIDI clock just like tap-tempo.
Thanks for your response.
However, I don’t understand how I can set the pedal to just SEND or just RECEIVE MIDI Clock.
It cannot send and receive at the same time right??
I need to set a Master and Slaves between my devices in order to Synchronise them all accordingly..
Can you explain how to just SEND or RECEIVE MIDI Clock please?
Thank you
