Home Forums Products Stompboxes Will a CV pedal work with Pitchfactor? Reply To: Will a CV pedal work with Pitchfactor?
#152869
    KentuckyThrash wrote:
    As I've been through 5 passive expression pedals now trying to get a smooth throw with the Pitchfactor, I'd like to ask: Will a CV expression pedal work?  I figure if the pedal is controlling the voltage it will be smoother throughout.
    Depends on your exact problem. If:
    1) The control range is bad, i.e. too tight at eithr the top or bottom, a CV pedal will help.
    2) The pedal is not reading the pedal quickly enough, so that changes are jerky, a CV pedal will not help.
