Reply To: Will a CV pedal work with Pitchfactor?
Home Forums Products Stompboxes Will a CV pedal work with Pitchfactor? Reply To: Will a CV pedal work with Pitchfactor?
#152873
KentuckyThrash
nickrose wrote:
KentuckyThrash wrote:
As I’ve been through 5 passive expression pedals now trying to get a smooth throw with the Pitchfactor, I’d like to ask: Will a CV expression pedal work?  I figure if the pedal is controlling the voltage it will be smoother throughout.
Depends on your exact problem. If:
1) The control range is bad, i.e. too tight at eithr the top or bottom, a CV pedal will help.
2) The pedal is not reading the pedal quickly enough, so that changes are jerky, a CV pedal will not help.
Great.  Scenario 1 is the case.  Can you provide any CV specs / recommendations for the pitchfactor?
