Home › Forums › Products › Stompboxes › Will a CV pedal work with Pitchfactor? › Reply To: Will a CV pedal work with Pitchfactor?
October 9, 2019 at 4:12 pm
#152887
nickrose wrote:
KentuckyThrash wrote:
Great. Scenario 1 is the case. Can you provide any CV specs / recommendations for the pitchfactor?
The PF wants an input between 0 and 3.3V.
It will not be damaged by values outside this range (within reason!), but the full control range will only be between 0 and 3.3.
Hmm. So a +5V expression pedal’s last 20% of sweep or so wouldn’t do anything? I don’t see any pedals out there with specifically a 0 to +3.3v range. Would the Mission SP-H9 work with the Pitchfactor? Is the H9’s expression input the same as the Pitchfactor?
