Home › Forums › Products › Stompboxes › Pre/Post Routing › Reply To: Pre/Post Routing
October 9, 2019 at 11:17 pm
#152896
Hi all,
I’ve set up 2 x H9s to my DJ mixer which has stereo FX send/returns. The issue I’m having is that one of the H9s is not generating the selected FX. I’ve swapped both units around and it’s still the same unit which is not generating FX. However, if I de-activate the FX then it stops sending through the FX signal from the other “working unit”.
On the face of it this unit looks to be working fine – lal the indicator lights are working etc. Is there a setting in the menu system I’m missing?
Thanks in advance,
Adam
