Home › Forums › Products › Rackmount › 1745M outputs question › Reply To: 1745M outputs question
#152935
rfactor
    jagulow wrote:
    I have a question on the 1745M, with regards to the Pitch Change Module. I know that the posted range of the PCM is +/- 1 octave. However- if the 1745M's '2X' switch is moved to the 'on' position, is the range of the PCM also, now, doubled to +/- 2 octaves?
    I don't remember.  (Sorry – 40 years ago!)  Most likely a 2X switch would have simply cut the sample rate in half without making other adjustments.
    Richard
