Home Forums Products Stompboxes H9 Option for Banks Using Aux Switch Reply To: H9 Option for Banks Using Aux Switch
#153109
bnjiman
    bohan wrote:
    You should be able to set up your Fractal MFC101 or Midi Moose in a way that certain banks and presets send certain PC numbers, which can recall presets on H9 accordingly. Then what you need to do is only to put those algorithms/presets in your H9 in an order as you wish.
    Thanks for the reply. Yes this is possible however I don’t have the controllers at present. Hoping similar functionality could be achieved using a three way aux switch if the h9 could be programmed to support preset grouping.
    Cheers
    Ben
