Home › Forums › Products › Stompboxes › Filter/EQ Sweep using h9 and expression pedal? › Reply To: Filter/EQ Sweep using h9 and expression pedal?
November 4, 2019 at 6:36 pm
#153116
Thanks. I’m quite surprised in this day of edm this is so tricky to find/do. This is video shows how the effect is done in ableton.
Can the same sweep be setup in h9 with the expression pedal putting a single frequency parameter up and down in frequency and simultaneously up and down in gain.
