Home › Forums › Products › Stompboxes › Space glitching out and running through menu’s › Reply To: Space glitching out and running through menu’s
November 5, 2019 at 5:37 pm
#153121
Thanks a lot for the tip, I had the exact same problem with my space-pedal. Glitching out, even in h9 control you could see the knobs twirling around. Had it on for aboiut 30 minutes now and no signs of erratic behaviour so far, knock knock.
I just opened it up gently and wiggled the ribbon-connector that was connected to the bottom board and seems to have worked.
