Home Forums Products Stompboxes Pitchfactor sounds like LP filter is always on Reply To: Pitchfactor sounds like LP filter is always on
#153136
camn
    Oh I hear it.
    I use the H9 version.. But I have had some dissatisfaction with the processed tone of the Pitchfactor as well.
    I think you are just mistaken that “it should not process signal” when set to 100% wet. It likely is totally processing signal, sampling the tracked note and outputting one at unison.
    Probably (I’m speculating), the tracked note is bandpassed to improve accuracy. Tracking all the overtones would be suboptimal, and would output multiple tones all over the place. So your processed output would also be bandpassed.
    I doubt there is a way to change it.. Except to use 100% dry or bypass when you want a clean signal.
