Home › Forums › Products › Stompboxes › Exp pedal looses half of it’s sweep. › Reply To: Exp pedal looses half of it’s sweep.
#153218
    Have you tried calibrating the H9 ? Look in the User Guide under "Expression Pedal".
    When you are done, make sure that PDLCAL is set to OFF, as, if it is left on, the pedal sweep can change as you describe.
