Home › Forums › Products › Rackmount › ADAT + SAMPLE RATE bug › Reply To: ADAT + SAMPLE RATE bug
November 16, 2019 at 2:41 pm
#153220
hi nick, does this mean you you guys have added support for ADAT SMUX?
nickrose wrote:
Your problem may be caused by the fact that ADAT really only works at 48K or below – this is limited by the capability of the optic fibre.
At higher speeds, ADAT can be converted to something known as S-MUX, where each ADAT channel occupies two of the 8 channels. Sounds like what you are seeing.
