Reply To: Emote: Inter-Connecting FX Chains
Home Forums Products Rackmount Emote: Inter-Connecting FX Chains Reply To: Emote: Inter-Connecting FX Chains
#153303
macgee
jbamberg wrote:
Well, as we like to say, it’s a simple matter of software.  One thing we’ve discussed is being able to run 2 algorithms per core if running at 44.1/48.  I think this is doable, although the synchronization can get tricky depending on how they are routed.  If the 2 algorithms were always paired in series, that would not be a problem.
The ability to run 8 algos in one FX chain would be amazing
Re Serial vs Parallel, that sounds fair, 2 on 1 core, run serial otherwise if parallel use another core
I imagine the challenge is how best to present this to the user
Thinking of my my old Digitech rack FX(which I still use), you would pick your config first then choose algos
Attached some images from PDF
