Home Forums Products Rackmount Emote: Inter-Connecting FX Chains Reply To: Emote: Inter-Connecting FX Chains
#153304
jbamberg
macgee wrote:
The ability to run 8 algos in one FX chain would be amazing
Re Serial vs Parallel, that sounds fair, 2 on 1 core, run serial otherwise if parallel use another core
I imagine the challenge is how best to present this to the user
Thinking of my my old Digitech rack FX(which I still use), you would pick your config first then choose algos
Attached some images from PDF
Thanks, this is very interesting.  I still think that the very deep users who want this level of customization might be better served with a patching tool that's like Vsig (or maybe is Vsig) but has higher level modules (each of which can be an algorithm in itself).  For example, that would allow you to route control signals between algorithms, which the other approach can't do.
