Home › Forums › Products › Stompboxes › Harpeggiator: can not get it in time with beat › Reply To: Harpeggiator: can not get it in time with beat
#153468
bobspencermusic
    I had the pitch sequence turned off. Even if I did have it on, I should hear some relationship between the sequence and the tempo – it’s not like there was a cross rhythm, it’s a completely different tempo.
    I tried different lenghts including 1/4. What is the length describing? The lenght of the entire sequence fitting into 1 1/4 note of the tempo? I know that would be way too fast – just looking for an explanation. The tap light on the pedal is flashing in time with the midi clock, but the sequence is not in time.
    FYI, I did manage to get it very close to in time by setting the midi clock to 150 BPM and manually setting the tempo in Harpeggiator to 204 BPM.
