Home › Forums › Products › Stompboxes › Request for a VST version of H9 Control › Reply To: Request for a VST version of H9 Control
not well no, this combined with the fact that putting any m4l device into any set greatly reduces stability. Max has gotten much better as its developed, and it can do some neat stuff, but I honestly avoid using it at all costs. and to be thorough, I've downloaded and tested every H9 M4L device I could find.
again, a proper VST would be quite awesome
Oh, just saw your reply. If you have to use a VST I'm sorry about that. If you want to do automation, you can just use your Ableton to send MIDI CC messages to H9 directly. Just set a MIDI CC mapping for the ribbon (expression pedal).
H9 Control talks to your PC via MIDI, that's why the USB cable can either used by H9 Control or the Ableton. However, if your PC supports Bluetooth, you can connect to your H9 wirelessly. Then you should be able to use Ableton and H9 Control simultaneously.
