Home › Forums › Products › Stompboxes › H9 with Prophet-6 midilearn? › Reply To: H9 with Prophet-6 midilearn?
December 23, 2019 at 2:04 pm
#153607
camn wrote:
Ive noticed the bugginess with setting MIDI PC or CC assignments, as well.
I found it works a little more reliably if I set it…wait a LONG beat… then back out of the screen.
If I back out too fast it doesn catch, or something.
Windows build? I’ve seen exactly that for several H9 Control versions now. AUX switch settings exhibit the same behavior. I’m sure I reported that, at some point. If you wait long enough, you can often see the set assignment revert back to its previous setting. It’s as if the default values don’t want to “unstick”.
