Home Forums Products Rackmount H9000R and 4 Cable Method (4CM) for guitar rig Reply To: H9000R and 4 Cable Method (4CM) for guitar rig
#153634
    As long as the H9K output is of a sufficient level, you can connect it directly to your high impedance input.
    Low will drive high, but high does not like to drive low. You only need further matching if the level is too low.
