Reply To: H9 controlled by EFX MK5, expression pedal
Home Forums Products Stompboxes H9 controlled by EFX MK5, expression pedal Reply To: H9 controlled by EFX MK5, expression pedal
#153639
bohan
thomasfxlt wrote:
What I cannot figure out is the V Beg (assume that means the beginning value when the program change is sent). You can enter a value, off or PDL. Each of those is resulting a value set on the H9 of "6" no matter what I do. I'm sure it's something I've got set wrong somewhere. I'm no midi wiz so any help is appreciated. I've posed the same question to MusicomLab group as well. Thanks for any insight.
I don't understand what you mean by this paragraph. You have some pictures or videos to demo this issue?
