Home Forums Products Stompboxes H9 into FXLoop of Fractal Audio AX8 Reply To: H9 into FXLoop of Fractal Audio AX8
#153656
    I think you may need to have words with Mr.Fractal.
    If the H9 works fine with a guitar and an amp, it is good to go, and there will be some external reason why your setup is not as you would want.
    To totally rule out the H9, "Restore Factory System Settings" as described in UM, and make sure you are using TS (mono) jack leads.
