Home › Forums › Products › Stompboxes › H9 into FXLoop of Fractal Audio AX8 › Reply To: H9 into FXLoop of Fractal Audio AX8
January 3, 2020 at 2:28 am
#153658
Thanks for the response. I found out the main problem – the FXLoop on the AX8 is also the OUTPUT 2, which I had never used so I had it turned all the way down. I turned it up and surprise it works. However I have some fine tuning stuff now, that I will post on the Fractal board. While I have the AX8 L&R output going into the L&R input of the H9 and the H9 L&R output into the AX8 L&R Input it is NOT coming out in stereo. While I just used the H9 direct into my monitors the stereo was marvolous, but through the AX8 I am only getting mono.
