Home Forums Products Plug-Ins Installing & Authorizing Eventide Plug-ins Reply To: Installing & Authorizing Eventide Plug-ins
#153666
DGillespie
    Lb12.benjamin wrote:
    Hello, Can I install equivocate on a offline computer please.
    I tried it on a online computer with the free version but i want use the autorised one to an offline computer.
    Please
    Yes you can do this. You need to authorize the offline computer first, then it can run EQuivocate while offline.
    If the computer can go online once you can authorize it using ilok licence manager available at ilok.com. You would put the computer online, install ilok license manager, and authorize the plug-in, then you can take the computer offline and it will be fine.
    If the computer can never go online you’ll need to use an ilok dongle to authorize EQuivocate. In this case just use an online computer to install ilok license manager and authorize the ilok. Then you can plug the ilok into the offline computer and EQuivocate should work well.
    Thanks,
    Dan
