Home Forums Products Stompboxes H9 Software 5.8.5.1 Problem with Logging In Reply To: H9 Software 5.8.5.1 Problem with Logging In
#153912
bohan
    camaro wrote:
    I'm able to view the entire keyboard. The problem is that your software, running on my android samsung galazy note 8, will not accept letters, will only accept numbers.
    Did you try the workaround I told you? When you type there and see the number pad, try rotating your phone to the landscape view. (You need to turn on the orientation change)
