Home › Forums › Products › Stompboxes › Best algorithm for Tom Misch/John Mayer auto wah/filter sounds? › Reply To: Best algorithm for Tom Misch/John Mayer auto wah/filter sounds?
#154006
    Here’s the algorithm you started with: ModFilter.  Yes, I think it can be close to what you’re after, but slightly varied in the sound results.  To me, the LOWPASS filter sounds like a 2-pole, with some soft saturation.
    The envelope follower is probably built exactly the same as other, similar algorithms, but it “feels” different (with identical settings & the same guitar setup).  Holds the filter open a little longer.
    I started with that BASS AUTO WAH preset, and tweaked it from there.  A little more ‘synthy’ to my ears trhan your example, but not in a bad way.  Again, the same kind of ‘tweaking rules’ apply here (as above).
    The 2nd ‘bottom row’ controls are optional, but I added a touch of ADSR to this one.  It opened up the filter sweep with another layer that wasn’t too obvious.
