Home Forums Products Stompboxes Bypassing expression pedals via Midi CC. Reply To: Bypassing expression pedals via Midi CC.
#154042
bohan
    birthofahero wrote:
    Thats how I thought it would work but I can't find any way to turn on/off the expression input/output on the h9 and there doesn't seem to be a midi CC# that activates/deactivates that setting on the h9.
    No, you don't activate/deactivate that setting on the H9. You do that on your ES8 by changing the MIDI CC yout ES8 sends out. For example, you can map MIDI CC 1 to the expression pedal, and MIDI CC 2 to the output volume on H9 (or in H9 Control. See attached image). Then you switch the MIDI CC messages by pressing a footswitch on your ES8.
