Home Forums Products Stompboxes New H9 Max Factory Preset List Reply To: New H9 Max Factory Preset List
#154158
bohan
    mistercharlie wrote:
    Thanks for the reply, but that video just shows things being put into the H9 Control folder. My problem is, I don't have that folder.
    What iOS version do you use? Did you try following the steps in that video? If there is nothing in a folder, you won't see that folder in the Files app. However, when you Move files, you should be able to see all folders on your iOS device. If H9 Control is installed on your iPad, that folder should be there, even you don't see it in the Files app.
