Home › Forums › Products › Stompboxes › Help getting Helix preset to load H9 preset in a patch by either CC or PC › Reply To: Help getting Helix preset to load H9 preset in a patch by either CC or PC
Glad you got it working. Just a couple things to consider:
Omni mode works, because it listens on all 16 MIDI Channels. But it can also become problematic, because it will respond to anything coming in. If your setup gets any more complicated, you might want to match each device to a single MIDI Channel; both the send/transmit and receive sides.
The H9’s Program Change Receive Map. Match the incoming Program Change message to whatever preset is loaded in the H9. Just be aware that some devices count Program Changes from 0-127; some start from 1 to 128. And the H9 presets number from 1-99. The “off-by-one trap” has been around since the dawn of MIDI.
You can save a preset in Bypass mode, and it’ll recall bypassed. Or you can use PC or MIDI CC messages to trigger Active, Bypass, or toggle between Active & Bypass.
