Home › Forums › Products › Stompboxes › H9 Crashes | H9 Max Dark 5.8.5.1 Crash › Reply To: H9 Crashes | H9 Max Dark 5.8.5.1 Crash
#154243
l_sap_ccs_crm
    Hello guys, I would like to ask you if there is a problem in my H9 Max.
    The symptoms are:
    -Freezing suddenly after some time of use (20-40 minutes)
    -Getting hot
    -Need to unplug the power adapter and wait a while to turn it again and use.
    -when it freezes, appear the letter “E” and sometimes letter “V” on the display, and no sound (nothing) comes out of the pedal.
    It happened once and when I immediately restarted (unpluging and pluging the power), it appeared as H9Core….and no Alg were listed.
    I restarted again and it started as H9 Max, but it crashed ang turned it off all by itself.
    I reinstalled the latest firmware again but it keept freezing after some use and to a pedal, in my opinion it is getting a little bit hot….
    I just bought the pedal, and would like to know if this is a sw or hw issue related, because I’m in Brazil and I hardly doubt that there’s someone able to fix it here.
